After re-programming the chip with a test programme I set up to test Eeprom read/write, I can write an integer value, e.g. 1234, to Eeprom mem location 1 and read it back. No problem. If I then write a different integer value, e.g. 2345, to the same location (mem location 1), the value read back is 0. I have to re-programme to be able to write to location 1 again. This happens at every memory location I try.
Has this got something to do with having to delete the memory location contents first before writing to it? If so, how do I delete the memory contents?
Kind regards.
Leo
EEPROM write problems with dsPIC30F4013
- Enamul
- Has thanked: 271 times
- Been thanked: 814 times
Re: EEPROM write problems with dsPIC30F4013
No you don't.Has this got something to do with having to delete the memory location contents first before writing to it? If so, how do I delete the memory contents?
Can you please post a simple program to demonstrate the issue so that we can have a look what's going wrong?
leoo
- Flowcode V4 User
- Has thanked: 41 times
- Been thanked: 9 times
The following example works as a simulation, but doesn't work in practice.
Kind regards.
Leo
Kind regards.
Leo
- 30F4013 EEPROM write_read 130321.fcf_pic16
- (10.5 KiB) Downloaded 361 times
