As an example:
In a custom component, I have a function with the following declaration:
void TFT_Do_something( MX_STRING Text)
/*Macro_TFT_Do_Something_Start*/
/*Macro_TFT_Do_Something_End*/
void FCD_Custom20_TFT_Do_Something(MX_STRING Text, MX_UINT8 MSZ_Text);
Also when using the component in flowcode it works fine and the fields window does not show this variable, however if you look at the customize component code window and the component macros prototype this additional field appears.
Interestingly if you use unsigned char* which is the definition of MX_STRING, the second parameter is not added in the generated code.
any ideas anyone?
many thanks
Sefi
