18F25J50 RTCC not running
Desdewit
Has thanked: 25 times
Been thanked: 11 times
Post by Desdewit »
Hi Guys
What else can I do to get the RTCC working.
The second counter keep giving me the same value "0x52 0x42" :cry: :cry: :cry:
Breeze RTCC.fcf
(8.5 KiB) Downloaded 897 times
Re: 18F25J50 RTCC not running
I think you may have to switch on the timer. You can do this using this C code.
t1con = 0x01;
Desdewit
Post by Desdewit »
Hi Benj
Thanks.. That did the trick :D
I'm so use to fc doing most of the setup these days that I over look the simple things.
I'm uploading the code as a basis to start from, for other asm users.
