How do I size my arrays with Boost C 7.04 version?
Carmen Garcia
- Has thanked: 14 times
- Been thanked: 3 times
Hello everybody:
It is possible to make arrays with Boot C 7.04 for PIC, but I don't know what does this sentence exactly "The only constrains is that an array must fit into a single RAM bank" mean??
In PIC guide I had found this for Data Memory (RAM memory) "Each bank extendes up to 7Fh, 128 bytes"
Does this mean that a array's size couldn't exceed the 128 bytes?? But Does the array's size be smaller than 128 bytes??
Thanks in advanced
Thanks in advanced
Carmen Garcia
Re: How do I size my arrays with Boost C 7.04 version?
8-bit PICs have a restricted RAM page size of 256 bytes so this is your limitation. Arrays smaller then or equal to 256 bytes should work fine.
There is a way to allow larger arrays using the idx2 parameter as described here.
http://www.matrixmultimedia.com/mmforum ... ays#p39852
Carmen Garcia
Hi Benj:
But in my PIC's guide appears "Each bank extendes up to 7Fh, 128 bytes"...
Please, another question:
I created this C code in a C FlowCode v5 Macro:
MX_UINT8 Array[20][17];
Array[1][1]=0xff;
FCV_Valor= Array[1][1]=0xff;
And the "Valor" variable doesn't set to 0xff.
Thanks you very much Benj.
Array[1][1]=0xff;
Carmen Garcia
Flash banks are 128 bytes, RAM banks are 256 bytes.
What about this instead.
20 x 17 = 340 bytes which is over then 256 page limit!
MX_UINT8 Array[5][5];
Array[1][1]=0xff;
FCV_VALOR = Array[1][1];Regards Ben Rowland - MatrixTSL
Carmen Garcia
Thanks you very much¡
Carmen Garcia
Carmen Garcia
Hello Benj:
I have set right the array's size for the appropiate use of RAM:
MX_UINT8 n=10;
MX_UINT8 Id=17;
MX_UINT8 Neighbor_Table[n][Id];
Neighbor_Table[1][1]=0xff;
FCV_VALOR = Neighbor_Table[1][1];
I suspect the type of variables doesn't match because I am using the portions of C Code I seen in the Main Code (putting in C View...)
I don't found a explicit guide for to create C code in C FlowCode Macro¡¡
MX_UINT8 n=10;
MX_UINT8 Id=17;
Carmen Garcia
Carmen Garcia
I know what happens...The C Code doesn't simulate in FlowCode.
Really does not exist a way for simulate the C code?
I was lookin for a Boost C simulator in the FlowCode Program Drectory (...\Flowcode\Tools\boostc\) but I didn't see anything.
Now I download a simulator from the official site, SourceBoost.
Any incovenience? Other alternatives?
Thanks¡
Thanks¡
Carmen Garcia
HI Carmen
I think Martin uses a program called pic simulator do a search on this forum as martin has linked to it quite a few times, i think you compile to hex then load the hex into the sim and away you go
Dazz
Dazz
hi Carmen
Heres a link to the sim mentioned above post by enamul http://www.matrixmultimedia.com/mmforum ... tin#p38159
Dazz
Dazz
Carmen Garcia
Thanks very much Dazz, but I not got much time and this simulator requires very much for learn...Finally I have opted for NO 2 dimensions arrays.
Thanks very much everybody.
Regards.
Regards.
Carmen Garcia
