Using a 16F877A micro in a project and require the 2 PWM outputs on RC1 and RC2.
I have set the ports up as per attached test file but can only get an output on RC2. I have tried changing the duty cycle so I could see which one was going to RC2 but all that did was shift the duty as the program executed which suggests that although I have set up PWM 0 and PWM 1 both of these go to RC2 ??. RC1 did nothing at all. I guess that I am missing something really obvious here..........
Thanks in advance Jack
PWM on 16F877A
Re: PWM on 16F877A
Hi Jack,
Since your using Flowcode professional V5, to receive better support please can you sign up for the correct Flowcode topic by clicking on this link please:
http://www.matrixmultimedia.com/mmforum ... =46&t=9958
To sort your issue out, you need to right click on the lower PWM (PWM2) on your control panel, select Ext properties and change PWM Channel from 1 to 2
Re: PWM on 16F877A
Thanks Martin, life will be easier tomorrow.....
Sorry for post in the wrong area and will use link next time.
Noticed that you are looking for commercial applications of Flowcode so will send you details of final project when complete because its for commercial use. Part of an auto-start system for our engine test rigs used in unmanned air vehicles.
Thanks again Jack
Thanks again Jack
