calculation tricks
brandonb
Has thanked: 175 times
Been thanked: 173 times
calculation tricks
Post by brandonb »
by putting this in tips tricks section was hoping to learn better coding myself and make it easier to find for others in future if others will add to these
 variable=variable|1<<7//set bit 7 in variable
 variable=variable&~(1<<7)//clear bit 7 in variable
 variable=variable^1<<7//toggle bit 7 in variable
 output=!output // toggles boolean variable
 if(  (a>b&&b<c)||(d!=c&&e<5)  ) //if left statment true or right statment true condition is true
 if(  a  ) //if the a  variable is above 0 the if statement is true, not limited by boolean
 a=~a//flips all bits,if a=10100000 a would then = 01011111
**************32BIT TO 4 BYTES / 4 BYTES TO 32 BIT ******************
(recall_4 = msB  recall_1 = lsB)   (d = msB  a = lsB)
if shifting bytes into a 32 bit number this is the minimum data types
recall_1 is a byte
recall_2 is a byte
recall_3 is a unsigned int
recall_4 is a unsigned int
--> being paranoid recall_4 i use ulong
input_number = 65535
a = input_number & 0xff // byte
b = (input_number >> 8) & 0xff // byte
c = (input_number >> 16) & 0xff // byte
d = (input_number >> 24) & 0xff // byte
output_number = recall_1 + (recall_2 << 8) + (recall_3 << 16) + (recall_4 << 24)
MINIMUM DATA TYPES TO BIT SHIFT 32 BIT NUMBERS.fcf
(15.5 KiB) Downloaded 467 times
Re: calculation tricks
Thanks for your very useful post Brandon.
It's much better all the calculations being in one place, rather than hunting around for them.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Brandon,
I'm afraid I noticed a couple of issues:
This is true for any 'a' that is unequal to 0. So for signed data types (integers) it is true for negative numbers as well as positive numbers.
    if(  ((a&&b&&c&&d)>10)  )//if all variables greater than 10 if statement true
What you are doing is using the logical and operator on a, b, c and d. The logical and operator is true if both left and right operand are not false. For numbers in flowcode (and C) this means the number is not equal to zero. So your expression is (a&&b&&c&&d) > 10, this means if all 4 variables are unequal to zero the left side of the expression evaluates to true. Depending on the representation of true (is it -1, 1, 255 or any other value) the result of the total expression may be true or false. Basically, the result of the expression may be true if all of the variables are non zero or never be true (depending on the C compiler used)
Best regards,
Jac
― C.S. Lewis
brandonb
Post by brandonb »
thanks kersing, i see what you mean on the (a&&b&&c)>10, it doesnt work the way i thought, when i tested it to see if my understanding was correct on it, i must have tested it in a way that just happened to give me what i thought could be interperted as this statement
if(  (a>10)&&(b>10)&&(c>10)   )
yep, two different things, thanks
please feel free to add and correct
