Hey!
16F648A EEPROM controller It can not be used.
What could be the problem?
Added to the compiler messages.
Thank you for your answers!
Solved
http://www.matrixmultimedia.com/mmforum ... pe3#p27772
PIC16F648A EEPROM problem
- STibor
- Has thanked: 116 times
- Been thanked: 113 times
- compiler messages.txt
- (3.15 KiB) Downloaded 635 times
- eeprom648A.fcf
- (6 KiB) Downloaded 671 times
Re: PIC16F648A EEPROM problem
Hi Simpi,
I have altered FCD file for your device, when I noticed you have spotted my post for FC4,
Just in case I have attached a modified fcd file for FC5
Place it in your fcd folder below is the path depending on if you have a 32 or 64 bit operating system
C:\Program Files (x86)\Flowcode\v5\FCD
C:\Program Files\Flowcode\v5\FCD
- 16F648A.fcd
- (10.37 KiB) Downloaded 598 times
