I have a strange problem when i place an output on the panel.
As soon as i replace it, the output (LED, RGBLED and LED array), the LED and the activation field are split!. So when i want to change fi the connection, right clicking the LED does not work, because the corresponding area is somewhere else. I can only find it by randomly clicking in the panel. This is very annoying. What can be the cause and remedy ?
Outputs in panel
Kenrix2
- Flowcode v5 User
- Has thanked: 72 times
- Been thanked: 177 times
Re: Outputs in panel
I just did a search for "panel bug" and this post was listed which looks similar to your issue:
http://www.matrixmultimedia.com/mmforum ... bug#p24031
It is for V4 and no remedy but, the last entry has an easy work around. Give it a try, hit run then stop.
You could also download the V5 Demo and use it to see if the problem follows.
I downloaded FC5 to a new directory, but the phenomen remains. It only affects the LED icons !
Sounds like an interesting phenomenon, certainly nothing I've ever experienced.
Out of interest what is your windows DPI set to?
Refering to the LED problem, i found a workaround to correct the strange behaviour. When i place an LED on the panel, i change the external properties from round to square or oval, and then back to round. After that i can move the LED over the panel whitout the LED and selection frame being split. Some hint to a solution ?
