Hello Friends
I read that there are some problems with flowcode
using UART at 115200 BAUD
someone can tell me if you used this speed whit PIC16F648A and flowcode v5 or send me any example that I can learn how to use it
thanks
Paul
usar 115200 pic 16f648a
Kenrix2
- Flowcode v5 User
- Has thanked: 72 times
- Been thanked: 177 times
Re: usar 115200 pic 16f648a
I asked myself a similar question after viewing a video of lights being turned on and off and dimmed all timed to music and I wanted to build it. I bought a copy of Flowcode Pro and actually did build it. The music part was handled by a PC. At first i was skeptical as to whether or not Flowcode was fast enough. It is. So to answer your question, yes, Flowcode can handle 115200 (that is the same baud rate i used) and that IC is just fine. Here are links to example files that you asked for (look for EB062 - RS485 - Example Files Flowcode v4 and also MX026 - Additional Files):
http://www.matrixmultimedia.com/product ... PHPSESSID=
http://www.matrixmultimedia.com/article.php?a=419
hello friend
thanks for your information I
I have a modem that works only 115200
I made flowcode simulated tests
and the simulation with fc v5 and pic 16F887 seems to be going
I read in the forum that when you use custom setting, there is something to adjust in c but not how to do this
have an example in this speed with any pic 16f??
While this works to 115200?
thanks for your help
Paul
Paul
