Address ( 0- 31 ) in RS 232 communication
karthik.devaraj
Post by karthik.devaraj »
HI all,
I can communicate my board with pc using rs232 communication and happening. When I'm connecting Multiple boards and converting 232 into 485 communication how can I address the board . That means If I'm sending value , then it will flow to all the boards. I juz want to make it as to activate in one board. Hope seting the address makes it easy.
Looking forward you all. Kindly post or suggest the flow code file
Re: Address ( 0- 31 ) in RS 232 communication
Programming tips and tricks section is not for questions or technical support.
I have moved your topic to a more suitable section.
Since you're using Flowcode 5 professional can you please click on this link:
http://www.matrixmultimedia.com/mmforum ... =46&t=9958
So you can register to enable you to post in this V5 part of the forums.
