SD Card carriage return
mb101
Flowcode v5 User
Has thanked: 1 time
Post by mb101 »
I've been trying for a while to get a carriage return written to a text file on SD card using the "Append_String_To_File" macro without any luck. I even tried converting the ascii / hex for a carriage return by various functions by still no joy. I've had a good look around but cannot find any similar posts, has anyone done this before or can you point me in the right direction? Pic / SPI / SD card all working fine, just the carriage returns. Or do I need to goto block write with "Write_File_Sector"?
Thanks in advance :P
Mark
Re: SD Card carriage return
Hi Mark,
Have you tried this in the string?
"test line \n"
if this doesn't work then you could try.
"test line \\n"
Otherwise you can assign this to a string variable and then use the string variable with the append string function.
CRstringvar[0] = 13
CRstringvar[1] = 0
