RS232 Data Viewer
acestu
Has thanked: 783 times
Been thanked: 223 times
RS232 Data Viewer
Post by acestu »
I have a 4d systems intelligent display which I have programmed with Visi Genie. I want to hook it up to a pic and see what rs232 data it sends when I push buttons etc, I have started to put a chart together but on the rs232 module there is Timeout byte that I am not sure about, if somebody can give me some pointers I would be grateful....
Thanks in advance
Acestu
rs232_displayed.fcf
(12.5 KiB) Downloaded 225 times
Re: RS232 Data Viewer
The timeout byte is how long to wait for valid data to be received.
0 = don't wait at all
255 = wait forever
The RS232 properties allows you to configure the timeout delays as iterations or as milliseconds.
A value of 255 will be returned if a timeout is detected and you have the return type set to legacy in the component properties.
