Lookup tables GetInts
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
I was looking for a way to get (in simulation) all integer elements from a Lookup Table. GetInts seems like the macro to call. As it does not return a result I expect the parameter should contain the values after the macro call. It does not work as expected, are my assumptions wrong?
― C.S. Lewis
― C.S. Lewis
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: Lookup tables GetInts
Hi Jac.
At the moment there is no way to return a pointer to an array - this may be something we need to look at but would change the simplicity of the 'return type' field.
This call should work as expected - it appears something in simulation is broken with regards to array concatenation, so I will look into it.
Jonny
Jonny
kersing
Hi Jonny,
I know there are no pointers at the moment, that is why I was hoping the array operation would provide a work-around. Ok, I'll wait for an update...
Jac
Jac
― C.S. Lewis
― C.S. Lewis
