old functions
Please add any feature requests for Flowcode version 6 here
Forum rules
STibor
Has thanked: 116 times
Been thanked: 113 times
old functions
Post by STibor »
I'm looking for the following useful features:
Hardware investment component:
Right-Click Menu
- Custom code
- connections
- Ext properties
The Flowcode V6beta supports all the controller.
The optional V6 Flowcode will continue to support all the controller?
3D view can be switched off?
Thanks for your response
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: old functions
Post by dazz »
HI STIbor
Ext and Connections are now in the properties panel right click component select properties and its down towards the bottom
Custom code is not there , but a lot of base components are so you would add a base component then make your component with your custom code ,link them together and your done
Beta supports all components and all versiones ie pic avr pic16 and arm, the final release will be the chip pack you select ie pic, then additional chip pack can be purchaced avr , so with V6 you will have one main install and extra chips pack can be purchesed and added to the main V6
if you open the dashboard panel and when selecting components drag and drop them then the 3D panel should stay closed
Dazz
