Open fcfx files
Please add any bug reports that require discussion here
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
wayne millard
Has thanked: 7 times
Been thanked: 12 times
Open fcfx files
Post by wayne millard »
Tried to open the example files but will not open if double click on icon but will if opened in flowcode.
Did not do this in the past.
Wayne
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Open fcfx files
Post by JonnyW »
OK, cheers Wayne. Sounds like a file association is missing in the installer. I'll mark it up as a bug.
You can tell windows of the association by right clicking the file and Open As... for now if need be.
Jonny
Re: Open fcfx files
Hi Jonny,
JonnyW wrote: I'll mark it up as a bug.
I posted about this bug yesterday on the bug report form.
Bug	Major	Issue with opening Flowcode from .fcfx		6.0.0	medelec35	15/08/2013
Description	Double clicking on fcfx extension opens FC6, then FC6 Closes.
JonnyW
Re: Open fcfx files
Post by JonnyW »
Hi. Sorry Martin, didn't think they were the same! Yes, its in the pending list, though we can't replicate that here.
Needs more investigation from us, I think.
Jonny
Re: Open fcfx files
No problem.
Also there has been no change in icon associated with fcfx extensions. Its just plain White.
I have now tried to open fcfx on two different PC's (both in 64bit win7 )
on the one at home it's as stated in the bug report.
The one at work has caused Flowcode to stop responding:
Not responding.jpg (57.68 KiB) Viewed 26508 times
Nothing on wincrash report.
So looks like this bug acts differently on different PC's
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: Open fcfx files
Post by dazz »
I don't seem to get that issue heres a pic of the demo.zip files show up ok on my system
I use Win8
Dazz
Re: Open fcfx files
Hi Wayne, what are your icons like for fcfx files?
Here is mine:
(17.92 KiB) Downloaded 8249 times
It's the same on both pc's
It maybe worth installing on my 32 bit vista laptop,
I will edit this post with results.
wayne millard
Re: Open fcfx files
I have the same problem on two PC's one is winXP and one is win7 they both do not show a icon only white blank sheet.
Wayne
Re: Open fcfx files
Another question:
Who has FC 3 or FC4 installed as well.
I tried to assign .fcfx with FC6 beta, but after going to Flowcode 6 Beta directory then browsing to Flowcode.exe, It keeps assigning it with FC3
FC6 beta was not in the list of recommended programs.
Only FC6 Alpha was in other programs.
wayne millard
Re: Open fcfx files
Hi Medelec,
I have v3, v4, v5 installed.
I have made a project using v6 and when finished it still has problem with the file extension.
Wayne
Re: Open fcfx files
wayne millard wrote: I have v3, v4, v5 installed.
Thanks Wayne.
Same here and at work.
Maybe that will give johnny a nice clue?
Unless Dazz says the same of course :P
dazz
Re: Open fcfx files
Post by dazz »
Hi guys
Have V4 V5 V6 installed, ,it's entirely possible that i did a file association with the first alpha, as it was a while back i cant remember
Dazz
Re: Open fcfx files
dazz wrote:it's entirely possible that i did a file association with the first alpha, as it was a while back i cant remember
I would be the same too.
V6 alpha was the end of March.
So I'm not surprised you cant remember.
I'm lucky if I remember my own name these days :lol:
JonnyW
Re: Open fcfx files
Post by JonnyW »
Hi. I think this is one for our dev manager Carl as he does the installer, but as he is away for a couple of weeks now I will have a fumble about and see what can be found. The more info the better - a good pattern will be easier to sort out.
Jonny
Re: Open fcfx files
Hi< I have just installed FC6 beta on a potable Craptop (with V4 and V5 already installed) and it does the same as my main PC.
I.e fcfx aew just plain white, and double clicking on the file opens FC6, then it just closes again.
Closes just after refresh component stage.
