PWM from FC5 not importing corectly
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
When loading FC5 that has PWM set duty cycle (8bit) then unknown or missing component is displayed.
Re: PWM from FC5 not importing corectly
I would like to add to this list, components not importing correctly:
one_wire
can
EEPROM
one_wire
can
EEPROM
With Patch2 installed PWM still not importing correcty.
Wong generic component icon is generated:
- Has thanked: 1135 times
- Been thanked: 299 times
Hi!
For info!!!
After install Path3, I still have the same problem. Maybe not fixed in this path.
regard.
Jorgen
For info!!!
regard.
Jorgen
Hi Jorgen,
I'm currently compiling a list of 'Patch 3 outstanding reported bugs'
So for I have 3 items on the list and that is one of them
Will be looking for more outstanding issues then posting it after have sorted something else out first.
Ok Martin!
It is only for info to help MM. By the way, It´s the same for EEprom.
Please do not believe it's to complain.
"As you know a fool can ask more than ten wise is able to answer"
Jorgen
Jorgen
Hi Jorgen,
I may have worded my post in such a way, it could be seen as criticising you.
This is definitely not the case!
Its great that you have found outstanding issues, and your not seen as complaining at all (in my eyes anyway)!
My post was trying to say (badly) that I totally agree with what your saying, and I'm was posting the same information.
To be fair on you, I will remove the points you mentioned.
I know I'm not mm staff, but your doing a great job of looking for bugs!
Sorry if I appeared to be negative, that was not intended.
Hi Martin!
No, no, Martin you have have NOT criticising or appeared to be negative at all. Absolutely NOT.
This: "As you know a fool can ask more than ten wise is able to answer" was only a joke from me, (we say here in Denmark for joking).
I understood your previous answer: as you always do, kindly, friendly, helpfull and doing a great job for everybody here. Seriously.
I continue to ask you.
Never no bad feeling from me.
Have a nice evening Martin.
Best regard
Jorgen.
Best regard
Jorgen.
Just an update with importing with FC V6.0.3
With The MIAC:
PWM component is now importing correctly (no errors displayed when running) Except for the settings, e.g period & Prescaler.
With The MIAC:
