Timer interrupt bug
Please add any bug reports that require discussion here
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
Timer interrupt bug
Attached is a flowchart that stops running when single stepping at the same point.
In the screen shot below, if press F8 when reached this point, flowchart will stop.
(24.77 KiB) Downloaded 3033 times
If the timer interrupt is removed, then flowchart will continue to run indefinitely.
The 1 second delay has something to do with the bug since if removed, again flowchart will continue to run indefinitely.
timer int bug.fcfx
(7.8 KiB) Downloaded 471 times
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Timer interrupt bug
Post by JonnyW »
Cheers Martin, I'll take a look.
Jonny
aanside
Post by aanside »
I find a similar bug in the Frequency Counter demo program.
It runs but, no matter how fast the button is pressed, the readout on the display remains at 1Hz (with the odd flicker to 2Hz). I have a program written in Flowcode 5 which has a similar structure and works perfectly. When imported into Flowcode 6 it show the same behaviour as the Frequency Counter example.
