Not sure if this should be a feature request or a bug.
Assuming bug as it may be a bit obvious to be a feature?
If you open a V5 flowchart with the same name (as you did on another occasion and saved as V6) then if prompted to save again, then there is no warning that the file exists, even though it does.
If file exits a warning should be flagged up, just in case the flowchart have the same name but are different.
Loading V5 Flowcharts saving as fcfx bug.
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
