Compiling Error After fixing imported FC5
Please add any bug reports that require discussion here
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
After fixing missing or unidentified components there are a few errors which look like could be relating to Link to and simulation settings:
Device:        PIC.16F.16F1939
Generated by:  Flowcode v6.0.0.57
Date:          Monday, August 19, 2013 10:34:08
Users:         0
      ***UNREGISTERED***
   NOT FOR COMMERCIAL USE
Errors when generating C source code:
Components test_v6.c : 1869 : error : Syntax error
Components test_v6.c : 1875 : error : Syntax error
Components test_v6.c : 2057 : error : Syntax error
Components test_v6.c : 2063 : error : Syntax error
FINISHED
The Flowchart is for testing purposes only so is not used for a real project.
Note: error shows Syntax error which is not much of a clue to whats going on.
Have to scroll up on the C code to see what component is causing issue :P
(156.61 KiB) Downloaded 428 times
Components test_v6.fcfx
(28.46 KiB) Downloaded 426 times
