In the past I have made I Flowcode program with well over 35 different macro's. The navigation to certain parts of the code may be some what difficult if you haven't worked on this code for lets say 2 weeks because of a holiday. When you get back to the code it very difficult to know where certain parts of the code is.
I think with A few adjustments we can make it even easier to search trough the code.
First off all: what I would like to see in the project explore is as follow,
If you open the project explore you can see all the macros, but not the level of the macro's.
Uhm how am I going to say this clearly in my shitty English.
You have macros in your main part of the code Okey, for starters I have my main code MAIN in here I create another macro called INIT. In this macro I do some stuff and after "some stuff" I create another macro to handle a specific object. in the existing project explore it would show like this.
-MAIN
-INIT
-Wifi_Module
-Startup
-Relays
-MotorCode: Select all
-MAIN
-INIT
-Wifi_Module
-STARTUP
-RELAYS
-MOTORSo the user can expand to see more details or Levels of his Flowcode.
Second:
It would be easier ad least I think when you click on a macro in the project explorer that in your main code window you also jump to that macro.
I hope that I have explained my self clearly.
Regards Jordy
