While debugging a component the pins do always not have to be connected which results in a message when trying to simulate. While the warning is very useful when creating a flow chart for deployment on a controller, it is annoying during the component debugging phase.
Please make this warning configurable for each flowchart.
Make pins not connected warning optional
Forum rules
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
― C.S. Lewis
― C.S. Lewis
Re: Make pins not connected warning optional
Hi Jac,
What about a button which is something along the lines of "don't warn me again this session".
kersing
Hi Ben,
I prefer it to be a setting for a flowchart. When working on a component and code using the component you want the warning while working on the later. Based on that you want to re-enable the warning when loading another flowchart, not when restarting FC. However, when switching between flowcharts often (which I currently do) it doesn't help a lot when it gets reset every reload. So a session based setting would help me shoot in my own foot or not be very effective.
Jac
Jac
― C.S. Lewis
― C.S. Lewis
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Hi. If you are developing your own component for this try:
http://www.matrixmultimedia.com/wiki/in ... nconnected
Note the property name is empty at the moment - I haven't got that sorted yet. If you do:
.Return = 1
It should skip any warnings.
Jonny
.Return = 1
Jonny
kersing
Hi Jonny,
Disable works fine. Combined with Component::GetInstance the perfect solution. Thanks!
Jac
Jac
― C.S. Lewis
― C.S. Lewis
