EB024 bluetooth Issue?
kmanng21
Has thanked: 1 time
Post by kmanng21 »
I'm using both flowcode V4.0 and V5.2-V5.4 for PIC micro, I download example 1 on home page and download to my EB006 16F877A
the program idea: send string "Start up:" to LCD -> send script 1 to PC -> send string "done" to LCD -> wait for string send from my computer and display on LCD
script 1 from example:
ATS0=1
ATS536=1
ATS512=4
AT+BTK="1234"
AT&W
ATZ
In flowcode V4, it's OK, very fast and smooth, I use "Hercules Setup utility" to manage COM port, and it receive+show all script 1 and I can send string from PC to my LCD very good
In flowcode v5, it's stucked when send script 1, Hercules Setup utility only receive ATS0=1 and my LCD only show "Start up:" and i wait for 5 minutes but it didn't send lines from script 1 to my PC like V4.
Please help me! thank you very much, sorry for my bad english
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Re: EB024 bluetooth Issue?
Post by Spanish_dude »
Is there any difference between your v4 code and v5 ?
Could you post both of them on the forum so we can have a look ?
- Nicolas
kmanng21
Has thanked: 1 time
Post by kmanng21 »
Dear Niclolas,
Here is a page for an e-block EB024:
http://www.matrixmultimedia.com/product ... PHPSESSID=
I downloaded this file
EB024 - Bluetooth Board - Examples Flowcode v4
I opened file: BT_EX1_Node_A-fc4.fcf by flowcode V4 and downloaded to my 16F877A, I connected my laptop to eb024 successfully and I can send text to eblock-LCD
when my 16F877A+EB024 start or reset, it send all words of script 1 to my laptop( I saw it by "Terminal V1.9b")
after that I used flowcode V5 to open+download program to that 16F877A, i connected my laptop to eb024 successfully but the program stuck at LCD only show "start up" and I wait for 10 minute, it only send "ATS0=1" to my laptop
thanks again!!!
from matrix e-block page
(9.5 KiB) Downloaded 412 times
Please can you update your v5 to version 5.5 and see if that helps with the issue at all.
If not then I will investigate the problem for you.
kmanng21
Has thanked: 1 time
Post by kmanng21 »
Hello Benj,
I updated my flowcode V5 to version v5.5.2.1 (30.1.2013) but nothing change.
I installed flowcode v5 on both Win XP and Win 7
Thank Benj very much.
I have made a minor modification to the Bluetooth code behind the scenes in the attached file. Please can you have a quick go using v5.5 and see if it helps the problem. If it does then I will roll out the mod to the component C file so the mod will be loaded into any project that uses Bluetooth.
BT_EX1_Node_A-fc5mod.fcf
(19.36 KiB) Downloaded 446 times
lavrukhin
Flowcode v5 User
Post by lavrukhin »
Hello, Benj!
I've got the same trouble with EB-024. Your modification doesn't correct the problem in FC 5.5
Could you help with any other solution?
If I don't use a script it works perfectly. I use Create command and Send command macro and the example works.
But I can't understand how to use these macro with AT+BTK="1234" command. I can't create this command because I need to use quote sign (") four times in Create command macro attributes. So I'd like to use script with EB-024 e-block.
You can add the quote to a string using this syntax.
"AT+BTK=\"1234\""
I'll have a look at the script code compared to the command code and see if I can spot what's going wrong.
sundgau
Has thanked: 5 times
Been thanked: 10 times
Post by sundgau »
I have the same problem. It's OK without script...
I look forward to the feedback...this still does not work with the solution: "AT + BTK = \" 1234 \ ""
My version is not Free edition
Bruno
MOMO
Flowcode v5 User
Has thanked: 1 time
Post by MOMO »
I use the EB024 for Bluetooth communication.
My program worked fine under Flowcode 4. Since I use Flowcode V5.5 it does not work because the program stuck in the macro "sendscript".
Do you have the solution to debug this problem?
Momo
Has thanked: 481 times
Been thanked: 699 times
If you are using sendscript, try this in the script, and ensure it has a carriage return (Ctrl+Enter) at the end
AT+BTK="1234"
Leigh
MOMO
Flowcode v5 User
Has thanked: 1 time
Post by MOMO »
Thank you for your reply, here is my script and I've done a carriage return (Ctrl + Enter) at the end.
ATS0=1
ATS512=4
AT+BTK="1234"
AT&W
ATZ
When I look in a hyperterminal there is only the first line of the script is sent!
Momo
Is there any reply from the Bluetooth device?
If you have connected hyper terminal in place of the Bluetooth, what happens if you reply: OK<return>
MOMO
Flowcode v5 User
Has thanked: 1 time
Post by MOMO »
I finally arrived to set up the bluetooth module sending the AT command as the "senscript" function does not work under FLOWCODE 5.5.
I get to communicate with the module, against when I use the command "STRINGRECEIVE" to know the length of the character string it returns me random values.
Do you have a solution?
sincerely,
Momo
