Assigning byte array in macro has issues with 0 values
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
When assigning a byte array to an byte array argument of a macro, the calling macro only gets the values up to the first element valued zero. See attached flowchart...
- arraytest2.fcfx
- (11.68 KiB) Downloaded 470 times
― C.S. Lewis
― C.S. Lewis
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: Assigning byte array in macro has issues with 0 values
Hi. Everything in the casting routine (that all assignments go through) was assuming byte array is string. That has been fixed now.
Jonny
Jonny
