Maybe a bit late for this version, and I suspect its may not be possible anyway.
Is it possible to have the component windows so I can just set them large enoughto show all the components they contain, but not have the scroll bar.
As they all seem to open at the same size. Some only have a couple of items in and can be make small, but then the Input and output dont show all the contents without the scroll bar.
Component Window Sizes
Forum rules
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: Component Window Sizes
Hi John. It may be possible to do this, but I will be looking at this bar later on and re-jigging it so there is search functionality and the bar is a bit dynamic - as libraries of components grow we will all need the memory of a chess master to know where everything is located, so a search bar and/or filter will be asked for eventually.
As is, I will see if there is a quick fix for this.
Jonny
Jonny
