will not activate
will not activate
I down loaded v6 trial. When I run the program the activate dialog opens. I tried to enter the info that I used when I downloaded the software. And it says "flowcode v6 doesnt exist on this account". So I tried manual activation. And when I go to that page the only info there is the license file. User name and key are blank. I also tried to "create an account" at the activation dialog and I created another account it but it still does not work.
This is on Win8.
This is on Win8.
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: will not activate
Hi Joe. Seems like something in the licensing system is playing up. Just our luck that this worked fine during Beta and is now playing up.
We are looking into it as a matter of urgency - hopefully things will be up and running soon.
Jonny
Jonny
let me know and I will test it for you.
I have been working with v5 and the microcontroller tutorial. (On another PC with WinXP).
- Been thanked: 1 time
Hi I just purchased Flowcode 6 yesterday and tried to activate and got this reply
Upon checking out the Flowcode Download site, I noticed the following statement
Please note Flowcode v6 purchasing is temporarily disabled while we fix some issues please check back again soon.
What should I do?
What should I do?
- (17.59 KiB) Downloaded 5238 times
Hi Mimiyum
Hang on a bit ,there's a slight issue with activation,which matrix are currently fixing, try again in a couple of hours, and see if it works,
Dazz
Dazz
I just tried activating FCv6 and it worked!
Now it is off to the tutorials!
JoeT
JoeT
Yehey! It's working now....next step is to learn how to work this....it's so different! Panic mode setting in
- Has thanked: 40 times
- Been thanked: 19 times
I purchased v6 PIC professional. Says I'm activated for 30 days.
When I check for updates I get a response that it does not recognize my License type.
Hi Shortcircuit
Did you follow the link in the email you got after purchasing, also try reactivating now and see if it activates fully for you(from within flowcode)
If not then send Davida a quick pm including your flowcode username(username for flowcodeV6 ) and explain the issues you are having, Don panic if you dont get an immediate responce to pm as the guys at MM are very busy at present
Dazz
Dazz
- JonnyW
Evening.
We have tended to find that most people have the same reaction at first, but then get used to the new features. We are still working on smoothing off that learning curve and hope to post regular updates so any first impressions are very welcome, and please just ask for any advice!
Jonny
Don't panic! Much of the stuff is put in to support the components that were originally written in VB, but are now written as Flowcode projects. If you just want to use Flowcode as you have previously done then it is much the same (with the odd difference).It's working now....next step is to learn how to work this....it's so different! Panic mode setting in
Jonny
Thanks for the encouragement!
Incidentally I checked the help menu and it says registered to 30day something. I tried to activate again and it still says the same thing after restarting flowcode.
When I click on licenses, it has an X on PIC16. I don't think it should be that way right?
- JonnyW
Hi. No, if you have the 30-day trial then this should allow access to all chips. Note you can still use the PIC16 to write a flowchart, but you can not compile it without the license.
If you PM DavidA with your account username he will be able to check on your account as to what is enabled.
Jonny
Jonny
