Simulation variable display question
billduck
Has thanked: 23 times
Been thanked: 16 times
Post by billduck »
I am writing a program, which in it's final state, will display battery voltages, in bar graph form, of 13 batteries. I am running a simulation to show voltages stored in an array. The attached picture is a screen shot of simulation. In the box "Specify the index of the array" I am not sure what to key in, as the prompt is partially obscured.
Thanks in advance.
Voltage Bar Graph.fcf_avr
Program.
(11.5 KiB) Downloaded 243 times
Screen Shot
(106.91 KiB) Downloaded 505 times
Re: Simulation variable display question
Hi billduck
Normally you can just press ok then all the arrays will be shown.
However it looks like there is a bug with adding local variable arrays to variable window (unless its deliberate with locals, i'm not sure).
What it should show is:
Enter variable between ReadVoltages.Vsub_i[0] and ReadVoltages.Vsub_i[9]
What you will need to add at the end of the variable is square brackets and array number inside.
So in your case with array of 10 you will need to add[0]......[9] on the end.
e.g
ReadVoltages.Vsub_i[1]
ReadVoltages.Vsub_i[2]
billduck
Post by billduck »
Got it. Thanks.
