Colour of system panel rapidly changes and Syntax error.
Please add any bug reports that require discussion here
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
I have sent this bug via Report a bug within flowcode, but will repeat it here since Not sure what information is sent (Would you mind letting me know please)?
For first bug: Run flowcode and altering an13
As the analoge slider is slowly increased the background of systempanel keeps changing:
For second bug compile to hex and following message is displayed:
(118.51 KiB) Downloaded 3538 times
Errors when generating C source code:
Demo_Board1_8bit_v6.c : 494 : error : Syntax error
Demo_Board1_8bit_v6.c : 504 : error : Syntax error
Flowchart opened was a fully working (apart from ADC issues) V5 flowchart.
There is also odd generated C code:
 Use :Waits until the switch is in state 'low'
       :The interpretation of 'high' depends on the polarity
void FCD_0ff_switch_base__WaitUntilLow()
    //Local variable definitions
    MX_UINT8 FCL_SWITCHVAL; // The state of the pin
    MX_UINT16 FCL_DEL_COUNT;
    MX_UINT8 FCL_OLD_SWITCHVAL;
    while (1)
        FCL_SWITCHVAL = FCP_GET(B, 0x80, 0x7);
        #if (0) // 0 == 1
        //Code has been optimised out by the pre-processor
        // #else
        #endif
        #if (0) // 0 > 0
        // #else
        #endif
        if ((FCL_SWITCHVAL != 0) == 0) break;
I believe it's LED array that's causing Syntax error.
(57.91 KiB) Downloaded 551 times
Demo_Board1_8bit_v6.fcfx
(39.27 KiB) Downloaded 500 times
Demo_Board1_8bit.fcf
(41.46 KiB) Downloaded 520 times
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Colour of system panel rapidly changes and Syntax error.
Post by JonnyW »
Hi Martin.
I think the issue is the ADC is a little strangely sized. The effect you can see is the ADC magnified many times. Resetting this should fix the problem.
ADC size
(7.53 KiB) Downloaded 3528 times
There does seem to be something odd about that ADC, and I'm not sure whats going on with it, but I can look into this.
Jonny
JonnyW wrote:I think the issue is the ADC is a little strangely sized. The effect you can see is the ADC magnified many times. Resetting this should fix the problem.
Hi Jonny, I have included the fc5 version because when open with FC6 the aspect ratio os all wrong, when dragged to correct size and shape then dimensions will look wrong!
Here is the odd thing, altering an13 on analog inputs physically alters the size of the ADC component.
So if it started off at 24mm, dragging slider of analogue window makes component resize to 100's mm
Hence different effects can be observed when dragging.
JonnyW
Post by JonnyW »
Hi. I don't know what black magic is going on inside the component - perhaps there is some weird maths that is causing this. Sounds like something we can sort easily enough though./
Jonny
