If Flowchart V5 contains INT interrupt, then after loading into FC6 the interrupt function will not work (Only tested in simulator).
Work around is just to delete interrupt, then add a new INT0 Pin interrupt.
V5 imported INT0
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
Re: V5 imported INT0
Hi Martin. Cheers, must be a mistake in the upgrader XML somewhere for that interrupt.
Jonny
Jonny
