When the LED array is placed on the either panels, when compile to hex there is a syntax error.
Even if component is not used within flowchart.
LED array causes syntax error
Forum rules
Only bug reports will be considered here. General questions should not be posted in this forum.
Re: LED array causes syntax error
Thanks Martin,
We are finally putting together a patch and this should fix the issue.
Getting this right has been one of the main hold ups for the patch. All working well now though.
No worries Ben and thanks.
its better to wait for a patch that solves all know issues. rather than rushing a patch that only solves a few issues.
I'm sure the wait is worth it.
