Signal Generator
JFinlayson
Has thanked: 5 times
Been thanked: 6 times
Signal Generator
Post by JFinlayson »
I would like to set up a couple of signal generators to simulate pulses on two pins at different frequencies. Is this possible in the new version? If so how can I add these.
The older the boy the bigger the toy
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Signal Generator
Post by JonnyW »
Yes, it is (depending on how high the frequencies need to be). Typically you would use a timer event and switch a pin (or pins) on the timer. See:
http://www.matrixmultimedia.com/mmforum ... 659#p51659
This is a squarewave generator component. You can export the component from the source file and include the component in your own projects.
if you need high frequencies then you may need to do this in a timer interrupt during simulation.
Cheers,
Jonny
JFinlayson
Thanks for the prompt reply, I will try this, typically the input signals are in the range of 300Hz to 3Khz
