Storing a Binary Bit Stream Best way
dswheeley
Post by dswheeley »
Hi All
Just getting back into flowcode after a while away so after some pointers...
I have a binary bit stream that will vary in length and bit rate, it is coming from a radio receiver.
I want to store this to play back through a transmitter at a later date, what is the best way to store a binary bitstream, internal EEPROM or an external one, SD card...
Also how would you read this into a Pic with flow code to store it... These may be simple questions sorry, I havent touched coding for a while so just trying to get a heads up...
Many Thanks
Darren
Re: Storing a Binary Bit Stream Best way
Hi Darren,
What sort of bit rate speeds are you looking at in hz?
