I've taken some code that worked in V5 and it doesn't update the simulation LCD in V6. I've upgraded to the most recent patch just today. I tried to get it to work from scratch in V6 with no luck so I imported the macro that I use to print to and scroll the LCD and it loops through the code but the LCD in the simulation doesn't update or seem to work.
I've not compiled the code in V6 to see if it's completely broken or just something wrong with the simulation.
Ideas?
Trevor
LCD Scroll Doesn't see to be working in the simulation
- Been thanked: 2 times
Re: LCD Scroll Doesn't see to be working in the simulation
Hi Trevor,
I agree with you about the scroll function not working.
Although the best way is for scroll function to be fixed.
Meanwhile for an alternative, how about this ?
http://www.matrixmultimedia.com/mmforum ... 42&#p50742
- JonnyW
- Has thanked: 63 times
- Been thanked: 290 times
We are testing a patch today and are due to release it Monday. This will scroll the LCD in simulation correctly.
Cheers,
Jonny
Cheers,
Jonny
