Online bug reporting
Mantas
Has thanked: 57 times
Been thanked: 27 times
Post by Mantas »
Hello MM,
Is the online bug reporting being monitored? Some of the reported bugs is hanging there for quite a long time...
Best regards,
Mantas
Science is my true religion.
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Online bug reporting
Post by JonnyW »
Hi.
Do you mean the bug reports that are generated from Flowcode? Yes, I am keeping track of things. Some can be fixed and some go towards building up a pattern if complicated or hard to replicate bugs are reported.
If this is from the on-line form, we do our best to get through these, but only have so many resources, sometimes it does take time - is there any particular bug you are after sorting?
Cheers,
Jonny
Mantas
Post by Mantas »
Hello Jonny,
Yes, EB031 board. Mloader does not find it after compilation. Just shows message to connect the device, and no restart or on off procedures are helping. Do I need to update bootloader?
Mantas
Post by Mantas »
Hi Jonny,
Any news?
BR,
Mantas
JonnyW
Post by JonnyW »
Hi Mantas. We (re Ben) is just looking into this now, there was a bug reported in MLoader so we are trying to replicate it.
We are hoping for a patch relatively soon, so hopefully this will make it in.
Jonny
Hi Mantas,
You can resolve the issue for now by deleting the mLoader folder from the "Tools" directory and replacing with the contents of this zip file.
mLoader.zip
(338.76 KiB) Downloaded 396 times
Let us know how you get on.
Mantas
Post by Mantas »
Hi guys,
now I am getting this error:
(155.53 KiB) Downloaded 1447 times
Any clues why?
Cheers,
Mantas
JonnyW
Post by JonnyW »
Hi. That might be the incomplete ICD plugin reporting an error.
Find <Flowcode install>\plugins\dll_dbg_icd.dll and, if it is there <Flowcode install>\plugins\dll_dbg_ict.dll
If you move these to another folder (close Flowcode first) then this hopefully fixes the problem. If not, let me know. ICD is due in 6.1, and the DLLs were added as an oversight on my part. The ICT should not be there at all, but unfortunately our patch tool does not delete files as far as know, so I can not get rid of them from earlier versions.
Jonny
Mantas
Post by Mantas »
Hello Jonny,
So as I understand with recent release I can not work with ICD? If so when do you expect to release 6.1 patch?
Cheers,
Mantas
JonnyW
Post by JonnyW »
Morning. Yes, we are working on ICD at the moment.
I am hoping that ICD will be back in before 6.1 - there are a few issues here and there to sort out. Main changes come from the additional support for the EB006 v9 boards which use a different USB comms (all previous ICD modes will be supported). I can not give an exact date because things are always cropping up, but hopefully within a fortnight ICD will be in a working build.
Jonny
