I have tried to make 1 sec pulse with a pic. It is also no problem. But I would like to use a watchcrystal 32.768 kHz crystal. When I use a watchcrystal 32.768 kHz crystal,
the oscillator will not run. No matter how I configure crystal settings in the config it does not work. Is it not possible to use such a "slow" crystal directly on Pic. or should we use C code with options for OSCON. Perhaps it can not be done with all types Pic
If it can be done with watchcryslat 32.768 kHz is there anyone who will be helpful to change the attached example. It could even be a 12f pic or similar
I have tried searching on the subject, but without success.
Thank´s in advance.
Jorgen
