Dear,
I will in oefening6.fcfx (see attachment) the keys display on the miac module.
The flowchart simulation work perfect but the software will not load in the miac module.
There are errors in the code.
What is here wrong?
Best regards
Nazaire Verrue
Miac keypad
Nazaire VERRUE
- Been thanked: 3 times
Re: Miac keypad
Hi Nazaire.
For target device,
If you select 'MiAC' instead of 'MIAC System', then your project should compile for you.
For target device,
