Flowcode 6.0.3 Released
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Post by JonnyW »
Good morning.
We are pleased to announce that Flowcode 6.0.3 has been released.
You can get the patch by clicking Help -> Check for updates in Flowcode.
A note on this patch:
We have had reports of graphical lockups on previous versions of FCv6. I believe inconsistent OpenGL drivers are a main issue of this. For this reason I have set Flowcode to use a software OpenGL implementation by default if one is available. If you experience graphical glitches and Flowcode previously worked fine, go to Global Options->Application and select "OpenGL hardware" as the graphics mode. This will put Flowcode into a similar state to in previous builds.
Enjoy.
Jonny
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Re: Flowcode 6.0.3 Released
Post by JohnCrow »
Just installed the 6.0.3 patch and Kaspersky threw a wobbler :)
Says the fc_launcher.exe file has malware. (I know it hasn't) and tried deleting it.
It has also deleted the boostc_16F.exe file
Sorry didn't manage to get a screen shot of that one
Kaspersky Version 13.0.1.4190
JonnyW
Post by JonnyW »
Hi. Cheers John. We can, I think, pass these exes on to the security companies and hopefully get them white-listed. Its good to know, anyway.
I think it is probably because they are wrapped up in a security layer. I'm surprised Flowcode hasn't also been targeted, but fc_launcher.exe and boostc_16F.exe have not changed in this patch, so its probably a vkiller update that has introduced this.
Jonny
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Can we please get english back?? I'm running a dutch Win7 so FC6 defaults to dutch. Trying to set the language in 'Options' lists a lot of languages, but either I'm overlooking english or it is not there...
What do I need to do to switch FC6 back to english??? (Which file(s) do I delete?)
― C.S. Lewis
JonnyW
Post by JonnyW »
Hi Jac. Very sorry, I never thought of those systems that defaulted to non-English!
Each language has a .mxd file stored in the languages directory. I did not generate one for English as I didn't think this was necessary! Clearly an oversight.
I will post a file first thing tomorrow.
Jonny
kersing
Post by kersing »
Hi Jonny,
No problem. I renamed both the mxd and dll for NL, solved the issue for now.
Jac
― C.S. Lewis
BUG Confiuration settings still not importing from FC5
Configuration settings are still not transferred from FC5 to FC6.
For example I have FC5 with configuration settings:
(59 KiB) Downloaded 5300 times
When loaded into FC6 settings are:
(118.67 KiB) Downloaded 5300 times
These settings are the preset default settings, and setting from FC5 have been completely ignored.
That would mean someone importing their FC5 flowchart into FC6, may find it may not work and is down to wrong configuration settings.
JohnCrow
Security Software
Post by JohnCrow »
As my earlier post, still been having problems with Kaspersky Internet Security 2013 and FC6 (also had problems with FC5 and FC6 with the latest KIS 2014.
I've used Kaspersky for quite a few years with no problems, but after a lot of tweaking it still wouldn't work with FC it had to go.
Just tried bitdefender 2014, and it works fine, I can run and compile with FC V5 and V6
Be interested if anyone else has tried bitdefender and what they think of it.
pantelisthrylos7
Has thanked: 1 time
Been thanked: 2 times
Post by pantelisthrylos7 »
kersing wrote:Hi Jonny,
Jac
How exactly can we do that. My default after 6.03 patch turned in Greek.
Thanks in advance
dazz
Has thanked: 474 times
Been thanked: 458 times
Post by dazz »
Too change back follow the pictures below, when you've pressed ok flowcode will ask to restart ,select ok and when flowcode reopens it should be back to English
Dazz
pantelisthrylos7
Has thanked: 1 time
dazz wrote:Hi
Dazz
Hello Dazz,
The strange is that when the language option is not ticked the language is by default Greek.
Can we do something about that?
Pantelis
kersing
Post by kersing »
pantelisthrylos7 wrote: The strange is that when the language option is not ticked the language is by default Greek.
Flowcode defaults to the language settings of Windows. f you want to use English right now you need to remove/rename the language files for Greek. The files are in
32 bit windows: c:\Program Files\Flowcode6\languages\
64 bit windows: c:\Program Files (x86)\Flowcode6\languages\
The files you need to (re)move are:
FlowEL.dll
FlowEL.mxd
― C.S. Lewis
pantelisthrylos7
Has thanked: 1 time
FlowEL.dll
FlowEL.mxd
Thanks a lot. I appreciate!!
