LCD 16X1 problem
fotios
Has thanked: 109 times
Been thanked: 117 times
LCD 16X1 problem
Post by fotios »
I bought two 16X1 LCDs, one cheap from e-bay and one expensive MIDAS with large characters from Farnell UK, both compatible with Hitachi HD44780 controller. If are configured in FlowCode as 16X1 only the first 8 characters are printed. If are configured as 8X2 then with proper calculation of cursor X/Y coordinates both can print correctly. OK the problem with this trick could be resolved but i have to write a huge code for a very complex project and the use of double component macros is not only time consumming, is also program memory consumming.
Can anyone help me please?
Best Regards FOTIS ANAGNOSTOU
brandonb
Has thanked: 175 times
Been thanked: 173 times
Re: LCD 16X1 problem
Post by brandonb »
hey fotio's i don't have a 16x1 but i pretended i did with a 16x2... assumming that the address is starting with 0x0 for first char and char 8 is 0x40, give this a try
in supp window i created these variables
char char_count=0;
char change_line=0;
then i created a new function for lcd called "check_line_status" in customize code section which is here
if(char_count>7 && change_line==0){
 change_line=1;
 Cursor(0,1);
char_count=char_count+1;
also in customize code section delete and replace code in lcd with the code in example for these c code funtions
clear, print_string, print_number, print_ascii, cursor
this should work in the background to make it do what you want :wink:
16x1 temp fix.fcf
(15.86 KiB) Downloaded 438 times
Spanish_dude
Has thanked: 63 times
Been thanked: 102 times
Post by Spanish_dude »
Have you tried just keeping the configuration at 16x2 and only writing on the first line ?
fotios
Post by fotios »
Spanish_dude wrote:Have you tried just keeping the configuration at 16x2 and only writing on the first line ?
Yes, i tried the 16X2 configuration but again the same problem, only first 8 characters are printed.
Thanks friend by anyway.
Spanish_dude
It must be that the DDRAM on your LCD is re-arranged differently than on the 16x2 LCD from Matrix Multimedia, even though it's compatible with the HD44780 controller.
Maybe it's like Brandonb said. Instead of having a continuous DDRAM line from 0x00 to 0x0F, you have an LCD with a DDRAM going from 0x00 to 0x07 for the first half and 0x40 to 0x47 for the other half.
fotios
Post by fotios »
My LCD is 16X1. Here a picture how it prints in 8X2 configuration. Attached is the datasheet.
Pilium LCD1.jpg (120.26 KiB) Viewed 11203 times
MIDAS LCD 1X16.pdf
(1.29 MiB) Downloaded 435 times
brandonb
Post by brandonb »
fotio's post your flowchart and i'll change the code to make it work for you
fotios
Post by fotios »
brandonb wrote:fotio's post your flowchart and i'll change the code to make it work for you
OK fellow, since you persist on it, here is the - incomplete - fcf till now.
PILIUM_CONTROL_LCD.fcf
(85.84 KiB) Downloaded 431 times
brandonb
Post by brandonb »
try this... use it as a 1x16 that is addresses 0-16 for cursor
(90.14 KiB) Downloaded 719 times
fotios
Post by fotios »
brandonb wrote:try this... use it as a 1x16 that is addresses 0-16 for cursor
It works.
Thanks fellow from hot Arizona!
