Function Generator
JohnCrow
Has thanked: 364 times
Been thanked: 716 times
Function Generator
Post by JohnCrow »
I've just built a nice DDS Function Generator kit.
Price is under £50
http://proto-pic.co.uk/frequency-generator-kit-fg085/
Apart from the normal sine and square wave, it can also generate the following waveforms
Triangle
+ve Ramp
-ve Ramp
+ve staircase
-ve staircase
Sine is up to 200kHz, and the rest up to 10kHz
Output Amplitude 10V p-p
Although it will generate higher frequencies, they are not as pure as when below this limit.
Looking at the FFT signal on the sine wave shows it generates a high purity signal
All the SMD components are pre fitted, just leaving the thro-hole components to solder
Steve001
Has thanked: 460 times
Been thanked: 523 times
Re: Function Generator
Post by Steve001 »
What scope are you using john ? looks quite nice
steve
JohnCrow
Post by JohnCrow »
Hi Steve
Its the Rigol DS1102E
I'm very impressed with it.
http://www.matrixmultimedia.com/mmforum ... 34&t=12950
The screenshots are saved to a usb thumb drive plugged in the front of the scope.
Steve001
Post by Steve001 »
Hi John,
What's it like at 45 - 65 Hz on sine wave function ?
Can you also adjust the amplitude of the wave form also ?
JohnCrow
Post by JohnCrow »
Hi Steve
Amplitude can be adjusted down to 100mV
Sine purity is good even at about 50 Hz I'll do a screen grab of my scope if you want in the next day or so at 50 Hz so you can see.
For about £50 its very impressive, no problems with building as long as you have a decent magnifying glass :)
As I posted above, took about 1 hour to built. The SMD components are pre-fitted.
Only thing to be careful with is the push buttons are polarised internally, but can still be fitted either way round.
http://www.jyetech.com/Products/085/e08503.php
Steve001
Post by Steve001 »
Morning John,
Thanks could you check at atbout 45 Hz please ? see what it's like no rush i am away from wed till weekend
Cheers
JohnCrow
Post by JohnCrow »
Hi Steve
I've attached a sample of screen dumps from the scope at 45 Hz
ScopeShots.zip
(18.47 KiB) Downloaded 492 times
Steve001
Post by Steve001 »
Thanks for that John
They look a nice crisp waveform, plastic might be getting some use now :lol:
JohnCrow
Post by JohnCrow »
Hi Steve
Don't think you'll be disappointed with it if you order one.
The only niggle I had with it are the threaded standoffs that fit between the underside of the PCB and the bottom plastic base are very slightly too short.
When the bottom cover is screwed on it presses on the electrolytic capacitor on the back of PCB, causing the cover to flex slightly.
Not having any suitable longer ones in stock to replace them I used a small nut as a thick washer to extend them by about 3 mm, and used slightly longer bolts.
This could depend on the type of supplied capacitor though.
