I use the chip is 16 f877a, crystals is 19.6608 Mhz.
I want to use interrupts produce 500 KHZ square wave signals, but interrupt the maximum frequency of 19200 hz (1:1). How should I do? Help me, thank you
How to produce 500 KHZ square wave signals?
- STibor
- Has thanked: 116 times
- Been thanked: 113 times
Re: How to produce 500 KHZ square wave signals?
Use a 20MHz crystal.
PWM is used.
9 = the value of the Period register, duty cycle = 4 or 5
PWM is used.
- Has thanked: 1135 times
- Been thanked: 299 times
H Stibor!
Waov, what an experience just to be able to come up with this idea
The links you have attached, is this some of your projects?? If, great work
I still have loooong way
Best regard
Jorgen
Best regard
Jorgen
