Bug in the Flowcode 6.0.3
HjH
Been thanked: 2 times
Post by HjH »
Hallo,
Flowcode : 6.0.3
MCU : 24F16KA102
Tact : 8MHz
I wrote a small programm. You can see that in the attachment.
If I save and close the programm and Flowcode 6.0.3 and I reopen the Programm and Flowcode 6.0.3 the elements C-Code is emty and the Output is B0 instead of B8.
HjH
Test_V2.fcfx
(3.97 KiB) Downloaded 304 times
Test_V2.c
(2.6 KiB) Downloaded 347 times
JonnyW
Has thanked: 63 times
Been thanked: 290 times
Re: Bug in the Flowcode 6.0.3
Post by JonnyW »
Thanks, we will look into this.
We were due for a 6.0.4, but want to get things nice and stable for this patch, so if I can find the issue will get it in that.
Jonny
HjH
Re: Bug in the Flowcode 6.0.3 that restricted mywork
Post by HjH »
I have a issue reported ago 15 days, that extrem restricted my work. I works often with element C-Code that lost the text after new start. Can you a way my say how I can bypass the problem.
HjH
JonnyW
Post by JonnyW »
Hi. The patch with that fix will hopefully be out Wednesday. We put the release back until then for extended testing.
If you really need something out the door before then then add a calculation icon, right click and select 'customize the C code' from the context menu. This will act as an alternate C code icon.
Jonny
