IF function
echase
Has thanked: 49 times
IF function
Post by echase »
What is correct syntax for:
IF variable = 160 OR 192
I thought I put this statement inside the IF icon:
variable = 160 || 192
but I find that pretty much any value of the variable leads to the Yes branch and not just 160 or 192. All other values should lead to the No branch.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: IF function
Post by kersing »
The correct way to do this is:
variable = 160 || variable = 192
Your expression evaluates to:
IF (variable = 160) OR (192)
As 192 is not zero the result is always true, resulting in a 'Yes' branch.
― C.S. Lewis
echase
Re: IF function
Post by echase »
Many thanks.
Would be useful to put this in the Help file. I could find some limited info on AND, OR, etc. functions there but not much.
dazz
Has thanked: 474 times
Been thanked: 458 times
Re: IF function
Post by dazz »
look in the boost c directory \Flowcode\v5\Tools\boostc and ther5s a manual that give some examples etc
ive attached it below
Dazz
boostc.pdf
(635.25 KiB) Downloaded 333 times
echase
Re: IF function
Post by echase »
A related question. What is syntax for negative numbers?
In normal maths -20 is less than -10. But if I use in the IF icon:
variable<-10
and the variable =-20 it does not appear to return the yes answer.
I find I have to invert the numbers into positive numbers and do a more than rather than a less than test. But that uses more time/memory. Is there a simpler way?
Re: IF function
The more minus you go the lower the number.
So -20 is less then -10
-10 is greater than -20
echase
Re: IF function
Post by echase »
Think I was wrong. Got cofused by too much use of negative numbers
