Hi There,
I like to use my EB006 (V3) board as an (USB) programmer with the Proton IDE (version 1.0.3.6) (Proton+ Basic Compiler) Compiler version V3.1.0.9
But when I compile my program, I get the message (after a while) Registry errorL failed to get data for 'CONFIG8L'
I use PPPv3 version 3.14
I can't find the right answer on the forum.
Any clues?........What do I do wrong?
I use the same USB input as I do for Flowcode.
Also tried to program my 16F877A (with the right jumper setting on the EB006 board of course) with the Pickit3 on the ICSP connector, but that work neigther.
Hope You can help me.
Regards, Jan
Using EB006 als programmer for Proton IDE
Jan van de Vooren
- Has thanked: 2 times
Re: Using EB006 als programmer for Proton IDE
Hi Jan,
There is a fix for this detailed here,
http://www.matrixmultimedia.com/mmforum ... G8L#p32373
Jan van de Vooren
