I am trying to use a PIC 18F14k50 in order to communicate with a module using serial communication.
This module works with an 115200 baud rate.
In the RSR232 properties (in flowcode), the baud rate is limited to 38400. An option exists to use a custom baud rate. I used it and set the baud rate to 115200 as my module.
My final aim is to find which quartz I have to use to get this baud rate.
After reading the Datasheet (http://ww1.microchip.com/downloads/en/d ... 41350c.pdf) I found at pages 190,191,192 and 193 informations about that. Something like 8 arrays are giving the quartz's value according to three parameters (SYNC, BRGH and BRG16).
I do not know how are configured those parameters when flowcode send my program to the chip.
Is there someone who knows which configuration I have to use?
Thanks!
Best Regards,
