PIC30F3014 ERROR IN WRITING
sonic11
Has thanked: 7 times
Post by sonic11 »
Hi guys
I once again need your help.
I want to use in my project DSPIC30F3014 but I encounter a problem I can not write.
PICKit2 use with PK2 software
The programmer looks like writing, but if I try to read it says "Error reading address 0x0000000000"
Program and configuration used:
led.hex
(22.79 KiB) Downloaded 231 times
led.fcfx
(3.87 KiB) Downloaded 222 times
sonic11
Re: PIC30F3014 ERROR IN WRITING
Post by sonic11 »
Can someone help me?
I found these which may help.
http://www.microchip.com/forums/m452541.aspx
http://auschristmaslighting.com/forums/ ... opic=462.0
Let me know how you get on.
sonic11
Post by sonic11 »
Hy Benj
We proceeded as follows
Pic kit dspic30f3014
1Vpp pin connected to pin1, pin MCLR
2vdd pin connected to pin11, 21, 32,40 vdd
3gnd pin connected to pin12, 20, 31, 39 VSS
4pgd pin connected to pin9 PGD / emud
5pgc pin connected to pin8 PGC / EMUC
All VDD pins are disengaged with one capacitor of 100nF to GND
PS. I use an adapter ZIF socket and had no problems so far with any microcontroller
I have not used my dsPIC and not very clear if the configuration bits is good.
sonic11
Re: PIC30F3014 ERROR IN WRITING (solved)
Post by sonic11 »
resolved
The problem is that the USB port can not give the necessary current programming.
I managed to program using a 5V auxiliary power
