I`m working at a project with 18F26K20 and I use all the pins. Mean while, I need another pin and the only pin available is RE3. I set internal MCLR and if I compile, it return me the following error:
" SW.c(217:2): error: unknown identifier 'trise'
SW.c(217:2): error: invalid operand 'trise'
SW.c(217:8): error: failed to generate expression "
Here are the lines in "C":
" //Input
//Input: E3 -> SW
trise = trise | 0x08;
FCV_SW = ((porte & 0x08) == 0x08); "
I still cant attach files (*FCF) on that forum (don`t know why...)
How can I resolve this situation?
Thank you!
(Solved) SW on RE3 error on 18F26K20
kersing
- Has thanked: 553 times
- Been thanked: 1081 times
Re: SW on RE3 error on 18F26K20
Edit the file 18F26K20.fcd (found in the FCD folder of your Flowcode installation).
Find the line:
Replace with:
Find the line:
InputCmdOneBit="tris%p = tris%p | %m;\n%o = ((port%p & %m) == %m);\n"
InputCmdOneBit="#if '%p' != 'e'\n tris%p = tris%p | %m;\n#endif\n%o = ((port%p & %m) == %m);\n"
― C.S. Lewis
― C.S. Lewis
bercioiu
- Has thanked: 90 times
- Been thanked: 34 times
Thank you very much sire!
Everything seems to be OK now!
I have a hex
I have a hex
