mistake upgrade Flowcode 6.0.7.0
HjH
Been thanked: 2 times
Post by HjH »
i have upgrade Flowcode 6.0.7.0 installed. Then I got the message, that I hadn't a license for this product. Please can you correct the mistake. I would be obliged if do it without delay correct. I am still waiting on your answer to my complaint from the 2014.15.03. I'm very angry and can't advise the product Flowcode V6. I consider my complaint still upright.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Re: mistake upgrade Flowcode 6.0.7.0
Post by kersing »
Have you tried activating Flowcode after the upgrade? That solved the issue for me.
― C.S. Lewis
ajneal4uk
Has thanked: 1 time
Post by ajneal4uk »
I got the same message.
If you click on help inside flowcode and select activate then enter your user and password.
Andy
HjH
Post by HjH »
thank you for the messages. The activate dialog said my Flowcode 6.0 is activated. If I insert my Username and passwort, I get the error message "Username not found". The employee from Matrix Multimedia wrote in the e-mail from 14.10.2013 that this proplem is resolved. As you see the statement is not believable.
kersing
Post by kersing »
Try logging on to http://www.matrixmultimedia.com/accounts/index.php. Use the same user name and password for activation. Or (after logging in) go to the manual registration page and use the instructions found there.
― C.S. Lewis
HjH
Post by HjH »
thank you for the message. Regrettably has the manual registration not correctly worked. First I get the message the registration was successful. Then after few minutes I get the message the registration app can't start. You can see this in the appendix
Fehlermeldung zur Regestrierungsmeldung.JPG (23.68 KiB) Viewed 6356 times
HjH
Post by HjH »
thank you for the help. After PC restart, two registration and some Flowcode V6 starts was the registration successful.
DavidA
Has thanked: 58 times
Been thanked: 258 times
Post by DavidA »
It seems the online automatic registration has issues with non-basic characters, the umlaut in your username was causing the issues.
I have replaced the 'ü' with a 'u' so your automatic registration should work now.
