thermostat..why not work?
antoniopoli
Post by antoniopoli »
hi i'm new
I'm trying to do a thermostat. pressing the select button, the display screen should bring up the macro code where imposed and memorize a temperature value.
but this does not work.I attach the code, someone can tell me where am I wrong? and can correct it?
thanks
termostato02.fcf
(25.87 KiB) Downloaded 587 times
Re: thermostat..why not work?
Hi antoniopoli,
your flowchart is not working because you're reading switch only once at the start of main outside of the continuous main loop.
For your flowchart to work you must read the switch within your main loop (Loop While 1).
So you will have to move SwitchReadState component macro.
If you keep pressing F8 to single step you will see that switch read component is never accessed.
Since your using a professional version of Flowocode,
can you please register for V5 section by clicking on>This
antoniopoli
thanks!
antoniopoli
I modified the program and now I have another problem.
Flowcode tells me that the simulation is ok, I compile the exe and I plug it in "real pic simulator" but this does not work.
who is right? Flowcode? or real pic simulator.
I enclose the last flowchart that I did.
P.S. copy of Flowcode use that is not mine and I can not register it. I'm considering to buy Flowcode 6 professional but first I want to be sure that it works well
termostato05c.fcf
(26 KiB) Downloaded 584 times
joetp
Post by joetp »
Hi antoniopoli,
One year later I have been reading your posts about your thermostat.
This is my answer to your problem with Real Pic Simulator not simulating your project as the Flowcode 6 does.
Ok, I have built your project in Real Pic Simulator and it really works as fine as in Flowcode 6 Pro.
I understand that after long time elapsed you may not be concerned on this subject any longer, but useful info for anyone following this thread.
Josep
