i watched Benj's Video
http://www.matrixmultimedia.com/mmforum ... 58&t=12735
...after i copy properties from a Component for the new..
is it possibel to edit/change the macro function by user for a change, a append or a remove.
Example:
if i create a new "RS232" compo and copy the properties from RS232 to the new Component, can i change the
Macro Function "ChangeHWBaud"? ( can i see the Flowchart from this macro function and can i edit/change, append or remove code / events ? )
is this by doing "Customs Code" ?
example:
ChangeHWBaud(NewHardWareBaud)
ok..so my next question is where i can found the define in dies Macro for for the "ChangeHWBaud"?
( where i make my own for the new? )
i try to understand from 0 to finnish a new component how i must go on to create a new component,
at waypoint zero ...
so i try at first time like the video, to copy a component and added function.. this i understand and the conzept of FC is fantastic,
i would know, how i can add a new function that FC will compile the code right, Is there a Api description availabel or description how FC works append code or how customs code must be?
I read the C Code ...
example from the ChangeHWBaud..
in Macro stands:
// Call Component Macro
// Call Component MAcro: RS232::ChangeHWBaud(9600)
FCD_047b1_RS232__ChangeHWBaud(9600);
Where is the define from this Macro Code "FCD_047b1_RS232__ChangeHWBaud() ?
Is it possible to edit? ( how and where i make my own for the new? )
Thank you!
Best wishes!
Rudi
