Embedding an assembly project into Flowcode
Zane
Flowcode v5 User
Has thanked: 93 times
Been thanked: 76 times
Post by Zane »
In the distant past before i used Flowcode i use to write in assembly. I have attached an .asm file (it can be opened in a text editor) of a project i did for our kids playhouse. I have given the playhouse away and wanted to make it all work again. The problem i have is i need to alter the assembly for a different type of keypad and all my P16PRO programming gear is all gone now. How can go about embedding this code into Flowcode. I had a look at one of the examples using a C block and inserting code inside that by doing the following
asm
assembly code placed in here
I have attached a copy of the assembly file for any one who is interested in looking at the file that was written using Microchip MPLAB.
When it is compiled it generates a lot of errors. Not having any real experience with C i am not sure what i would have to change with the syntax in there to get it to be accepted by the compiler. I have removed the "list P=16F877A and #include <P16f877A.inc> as well as the "end" instruction at the end of the code.
Any help with this would be appreciated.
house.asm
Assembly file
(42.45 KiB) Downloaded 761 times
Re: Embedding an assembly project into Flowcode
Hi Zane,
This topic might be useful to you: http://www.matrixmultimedia.com/mmforum ... f=5&t=3230
Zane
Flowcode v5 User
Post by Zane »
Hi Ben,
Thanks for this link i will give it a try.
