Incrementing character string ASCII value
Mark
Has thanked: 20 times
Been thanked: 16 times
Post by Mark »
I am taking an existing file name, ABC01, and if present already, wanting to create a new name ABC02 to stop overwriting.
The file name is used in the FAT component.
Hence, I assumed that I would chop off the last character, increment it by 1, ASCII for '1' = 49 to get '2' fron ASCII 50 and then add it back to get the new name.
Char = Right$ (File_Name,1)
Char[0] = Char[0] + 1
Len = Length$ (File_Name)
File_Name = Left$ (File_Name, (Len - 1))
File_Name = File_Name + Char
File_Name_String = File_Name + ".csv"
what I get is test01.csv goes to test0ß.csv and then test0Ó.csv
What am I doing wrong? Is there a simpler way to do this?
Thanks,
Mark
Go with the Flow.
Has thanked: 481 times
Been thanked: 699 times
Re: Incrementing character string ASCII value
It might help if you could post your Flowcode file so that we can see the string allocations.
Another way to do that would be:
filename[20]
filename = “ABC01.csv”
filename[4] = filename[4] + 1
Mark
Post by Mark »
Thanks,
I have tried your suggestion (using [4] + 1) with the result:
test01.csv goes to
test0.csv then
test .csv
It looks like something more is going on than simply incrementing an ASCII value. I will post further if something comes to light which might be helpful to others.
Go with the Flow.
kersing
Has thanked: 553 times
Been thanked: 1081 times
Post by kersing »
Are these results in hardware or in simulation? Could you post your test code (fcfx file) ?
― C.S. Lewis
Hi Mark,
I have attached one way it can be done.
Hope it works the way you would like it to?
here probably are more smarter ways, but due to the time of night it is, my poor brain is going for the easier option :lol:
If you can read the file name, you should be able to use the Compare string function to see if the name already exists.
If so using the method in attached flowchart, if the file name exists then string can go from Test01.csv to Test255.csv
Only testing in the simulator.
File Naming.fcfx
(4.44 KiB) Downloaded 268 times
Just remembered about the string bug within FC6
So it will work with numbers greater than 99 you will need to increase the array sizes of both strings by 1
File Naming LCD.fcfx
(5.65 KiB) Downloaded 275 times
